Home > Technical > Wheel Alignment - advice
RRS PIMP
I was wondering if someone with some knowledge of wheel alignments could confirm if my recent wheel alignment calculations has been done to a satisfactory standard?
The wheel alignment was corrected using a hunter machine and I have been told they have been adjusted within the acceptable tolerances, but me being me would have liked it to have been closer to perfection.
Merry Christmas!
Post #446345 Wed Dec 24 2014 5:43pm
Bodsy
Site Sponsor
That's all fine Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #446348 Wed Dec 24 2014 7:47pm
flack
Actually I would say they have not quite spent enough time on the front, there is no excuse on a Hunter alignment kit for it to be spot on.
The problem with these settings are that if you have a small kerb banging issue it will knock it out and not being spot on in the first place it will be further out and wear your tyres out faster.
Also what are your front lower and upper bushes like and was it in TTM for the check.
Flack Thumbs Up
Post #446355 Wed Dec 24 2014 8:50pm
Disco_Mikey
Front camber is right on the limit. However, the bolts may have been seized in the bushes, preventing them from being adjusted. Toe is fine though
Rear camber is fine, but rear toe could have been set a little better, but still in spec
Post #446362 Wed Dec 24 2014 10:22pm
RRS PIMP
Thanks, that sort of puts my mind at rest.
Lower suspension arms, steering rack, ARB bushes and tryes all recently changed.
Come to think of it, it did feel very rushed. They managed to damage my alloys while putting the tracking equipment on, so when I go back I'll ask them to spend a bit more time on it.
Post #446368 Wed Dec 24 2014 11:15pm
myfirstrrs
Mine had a Hunter's alignment today now that summer wheels/tyres are back on. Front right camber was adjusted to its limit and was still at about -1.28 and the guy said it must be a worn bush stopping him from being able to get it nearer. He showed me the eccentric washer that was at it's limit. Any ideas please anyone?
Post #460621 Mon Apr 27 2015 9:44pm
