Home > Technical > What hose is this
Simon58
England 2008 Range Rover Sport TDV6 HSE Galway Green
What hose is this
Whilst having the bonnet open this morning I noticed I had a split pipe, I assume its the intercooler pipe, before I order a new one can someone confirm.
Also is it an easy fix, I can see the top hose clip, I assume you have to remove the engine under shield to access the bottom hose clip
Thanks
Simon
 About to get into a sport
Post #445005 Thu Dec 11 2014 11:43am
tanloverluke
intercooler it is Thumbs Up
you dont need to open the engine undershield. instead there is a plastic cover, held in place by 4 plastic expander clips. you'll find this cover on the drivers side, front wheel arch/front radiator location. it's very easy to remove the intercooler and replace. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #445009 Thu Dec 11 2014 12:03pm
Disco_Mikey
PNH500025
Approx £40 or so from a dealer
Takes 20 mins to fit, there is a little plastic trim in behind the wheel. Once removed, access is good, and fairly self explanatory Thumbs Up
Post #445010 Thu Dec 11 2014 12:04pm
Simon58
Thanks tanloverluke/Disco_Mikey About to get into a sport
Post #445011 Thu Dec 11 2014 12:05pm
