![]() | Home > General > A really basic question about brakes for my supercharger |
| frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79
I can't answer all your questions, but if you do some searches you will see that there are a number of people who have used non-genuine brake parts with varying results and the consensus seems to be to stick with genuine parts when it comes to the RRS SC brakes. I've used Pagid rotors and pads with ok results. I would definately not use "generic" parts in one of these, but I'm confident using other known brands (e.g. Pagid).
| tailormadefun Member Since: 06 Apr 2014 Location: Kent Posts: 51
Hi mate
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
As we have discussed before on the forum - telling customers that their brakes are 'almost worn out so it would be a good idea to have then renewed now' is the automotive equivalent of the old con when the travellers knock on your door and say 'I was just passing and noticed your roof/chimney needs fixing'. Slap in some cheap Chinese knock-off pads in about an hour and charge £400 - 500 plus (kerching - easy money).
| ian-r Member Since: 21 Jul 2014 Location: Nottingham Posts: 49
HarryRange, sounds like you have had a rough ride. Check if the garage is on http://www.goodgaragescheme.com/ - if it is complain to them and they should review. But I would advise your first port of call is trading standards. Ultimately they will listen to the details of the complaint and see whether others have made similar ones. They will also tell you whether you can claim from the garage. Did you save the old brakes (im guessing not as it is not usual practice)? What was the fault with the new brake pad? Did you save this?
