Home > In Car Electronics > Sat nav wont access postcode or address screen
paul2415
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
have a 2007 hse sport with factory sat nav,on the destination screen when I touch the postcode or address buttond the green square lights up around the button briefly but will not go to either screen for input ?? if I use previous destinations and select then it will calculate the address etc so works but cant access new inputs,hope someone can head me in the right direction,thanks.
Post #444136 Tue Dec 02 2014 10:39am
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
put your hand under the front passenger seat and un plug unit for a few minutes then re plug and see how you go
Post #444196 Tue Dec 02 2014 10:17pm
paul2415
thanks for the advise,but tried that and still don't work ?? thanks.
Post #444611 Sun Dec 07 2014 10:40pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Probably a stupid suggestion but I presume you're stationary when you try it? Otherwise it won't work
Post #444613 Sun Dec 07 2014 10:55pm
jimbg
You are on GB as the country? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #444614 Sun Dec 07 2014 11:09pm
paul2415
Yes I am stationary and in park,the previous destinations work if selected and will calculate the route if selected, just cant get to the postcode or address screens,when I press these buttons the green square around the button highlights and the dvd runs up but nothing happens ?
Post #444766 Tue Dec 09 2014 1:41pm
Disco_Mikey
Hard reset first Thumbs Up
Post #444770 Tue Dec 09 2014 1:54pm
paul2415
How would I go about that ? Thanks
Post #445053 Thu Dec 11 2014 6:07pm
Paddi
Easy peasy. Unlock car and remove key, open bonnet and leave for at least 5 mins until everything powers down (car goes to sleep). Disconnect both positive and negative battery leads from the battery posts. Take a single jump lead and connect the positive battery lead to the negative battery lead for a few minutes. TAKE GREAT CARE NOT TO LET ANY PART OF THE JUMP LEAD OR THE BATTERY LEADS TOUCH THE BATTERY TERMINALS.
Disconnect the jump lead and reconnect the battery as normal. 2008 MY Java Black TDV8 HSE
Post #445137 Fri Dec 12 2014 4:03pm
