Home > Maintenance & Modifications > Door Mould Clips?
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Door Mould Clips?
Can someone help and tell me what clips I need to buy for the exterior door mould piece.
This door mould keeps getting loose when going over a bump and I have to keep hitting the mould to clip back in position.
How annoying ! Rolling Eyes
Post #444112 Mon Dec 01 2014 10:44pm
It uses two different clips which you can get from your local LR dealership. I have the same problem with mine and even after trying to replace the clips it still does it.
I really fail to see the point of the mouldings. They don't even look good.
Oh, DYC101420 and DYC500110G are the clips part numbers I think. Or perhaps someone tried to fix it previously with a mix of clips - I had asked the dealer to do it at a service once and they do seem to be inept. 2012 SDV6 - it's missing a couple of cylinders
Post #444118 Mon Dec 01 2014 11:47pm
Harry HST
Are we both on about the same trim...
The lower door trim on the exterior which is attached to each door...
Post #444120 Mon Dec 01 2014 11:57pm
I think so, yes. The sticky-out bits at the bottom that are normally textured and black but are usually colour coded by most on here. See edited previous post for the clip numbers. 2012 SDV6 - it's missing a couple of cylinders
Post #444122 Tue Dec 02 2014 12:01am
SRE
Spain
There is a search function on this forum, try and use it
http://www.rrsport.co.uk/gallery/albums/us...20clip.JPG In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #444129 Tue Dec 02 2014 9:43am
SRE
Spain
http://www.lrdirect.com/DYC101420-Trim-Cli...=DYC101420 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #444130 Tue Dec 02 2014 9:46am
Harry HST
How easy is the door mould to remove?
Some forums state you have to slide then pull off whereas others state you can just pull them up and they unclip?
Post #444131 Tue Dec 02 2014 9:49am
I seem to remember it is clip and slide - hence the different clip fittings. 2012 SDV6 - it's missing a couple of cylinders
Post #444134 Tue Dec 02 2014 10:20am
Sag
Harry, check the last post in this thread http://www.rrsport.co.uk/forum/topic30928.html LCFC. Receiver of threatening letters from Overfinch.
Post #444156 Tue Dec 02 2014 5:08pm
