Home > Maintenance & Modifications > List of correct fluids
needle
Can anyone tell me the correct fluid for the diffs and capacity please for a supercharged 05
Post #443912 Fri Nov 28 2014 7:42pm
Bodsy
Site Sponsor
Assuming it's auto, then it's castrol saf-xo now replaced by castrol syntax
Front 0.61litres
Rear 1.1litres istr Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #443920 Fri Nov 28 2014 10:23pm
If the rear is the locking one then it's 1.5L of Castrol SAF Carbon Mod Plus 2012 SDV6 - it's missing a couple of cylinders
Post #443930 Fri Nov 28 2014 11:24pm
Bodsy
Site Sponsor
Yes, didn't bother going into locking diff as there are so few Rrs with locking diff that it's unlikely he has it.
But you are right for locking diff. Thumbs Up Bodsys Brake Bible
See it HERE
Post #443931 Fri Nov 28 2014 11:28pm
needle
lol ok thanks but i better do a search to find out how to tell as just bought it .))
Post #443944 Sat Nov 29 2014 11:06am
The only way, short of taking it off road in slippery conditions or in to a proper axle twister, is to look at the rear diff. Raise the vehicle to off road height and then look through the rear wheel arch under the body. You should see the EPB box and the rear diff. If you have a motor on the rear diff then it's the locking one. If no motor, it's the open diff. As Bodsy says, the likelihood is that you have the open diff.
See here for a photo of a locking diff as seen through the rear wheel arch:
http://www.disco3.co.uk/forum/topic91421.h...fferential 2012 SDV6 - it's missing a couple of cylinders
Post #443948 Sat Nov 29 2014 12:05pm
needle
cheers .)
Post #444365 Thu Dec 04 2014 5:14pm
