Home > Maintenance & Modifications > Engine Cover - Rattle/Buzz
SRE
Spain
Thought I would check the Map sensor as I wanted to see what difference Blanked EGR valves had made, also I had noticed a very small "buzz" from the engine bay.
I whipped the Engine cover off no problem, only to find the sound deadening foam left on top of the engine, basically the sponge layer that is normally glued in place on the underside of the engine cover moulding had just fell away. In my case I left it alone and just popped the cover back on.
On a positive note, I now my hearing was 100% OK, Thumbs Up as the buzzing noise vanishes it I lift the engine cover a tad, Thumbs Up the downside will be how much the stealer will want for a new cover Big Cry In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #443869 Fri Nov 28 2014 10:42am
SRE
Spain
Looks like I am not the only one.
Don't like the price, makes you wonder, I bet there are quite a few Sports and Disco's running around with just the Plastic cover minus the sound deadening pad.
http://www.disco3.co.uk/forum/topic106988....e+foam+pad In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #443875 Fri Nov 28 2014 11:51am
SRE
Spain
All quiet
New engine cover fitted today along with new rubber cover mounts, car now sounds like it should Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #444939 Wed Dec 10 2014 6:32pm
Disco_Mikey
I wedged mine with a piece of cardboard Embarassed
Post #444947 Wed Dec 10 2014 7:31pm
Mister B
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
sounds like one of my "fixes" Whistle Rolling with laughter
Post #444957 Wed Dec 10 2014 7:57pm
SRE
Spain
Mikey
Only you Thumbs Up Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #444961 Wed Dec 10 2014 8:18pm
