![]() | Home > General > Battery drains when car left unlocked |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
Bit here;
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9086 ![]() ![]() ![]() |
If you leave it unlocked then it'll never go to sleep. If it stays awake then it uses lots of battery juice. 2012 SDV6 - it's missing a couple of cylinders
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
Mine is garaged every night, sometimes not moving for a week at a time and is never locked, never had a problem with the battery running down 2010 RRS, TDV8
Portman Len Member Since: 09 May 2011 Location: Suffolk Posts: 57 ![]() ![]() ![]() |
That's how mine used to be, although not as long as a week. Car is only three and a half years old, so I'd expect a battery to last a little longer than that. Always owned Jaguars before switching to Range Rover, and typically a battery would last around six years. 2011 Range Rover Sport 3.0 TDV6 HSE |
Just spoken to my dealer, who stated that when the battery in the RRS gets low, the car never recharges it fully - just maintains it at the same level. He reckons it's unlikely that the battery should fail after three years, so suggested putting it on a trickle charge overnight with a very low amp battery charger, and see if that sorts out the problem.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4502 ![]() ![]() ![]() |
Your dealer is correct |
Latest update...
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 ![]() ![]() |
Whilst a battery, if the car is used normally, should last longer than 3.5 years, I doubt that any car dealer or manufacturer would do anything other that laugh at the thought that they should in some way contribute towards a replacement since they cannot know whether the battery has been mistreated or not. |
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 502 ![]() ![]() ![]() |
My battery on the 2011 died at 3yrs 9months
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
Mine was replaced under warranty at just over two years old ! SVR 2018 in Santorini Black. |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
Just replaced the battery on my honda CRV- it was 13 years old and done 105k.
Well, my faith in human kind has been restored!
Result. |
