![]() | Home > Technical > Steering issue?? |
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 ![]() ![]() ![]() |
its the uj at the bottom of the steering column , mine was the same took it off wd40 free it off good as gold or you could buy a new one |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
RRS has a Servotronic valve on the steering rack. Very common for wiring issues to this valve, causing heavy steering.
0ane Member Since: 15 Sep 2014 Location: Sheffield Posts: 22 ![]() ![]() ![]() |
There's no fault codes stored.. So the UJ where is this located and how easy is it to replace? |
QMN500240
jprr Member Since: 15 Mar 2015 Location: Essex Posts: 14 ![]() ![]() |
Hi
WD on the uv joint and has been fine ever since mate |
Thanks for the prompt reply. Is there a diagram or instructions for oiling the steering column and associated areas that need oiling?are they easy to get to for a competent DIYer??
Brooksey90 Member Since: 31 Oct 2015 Location: North yorkshire Posts: 4 ![]() ![]() |
Hi I've just bought my first RRS last week and I think the steering is faulty I've had discos before and driven other range rovers but this one just seems real heavy at all speeds it never changes. Lock to lock is smooth and the wheel centres it's self after turning could anybody shed some light please I've checked fluid level is correct and I have no leaks.
Hi I've just bought my first RRS last weak and I think the steering is faulty I've had discos before and driven other range rovers but this one just seems real heavy at all speeds it never changes. Lock to lock is smooth and the wheel centres it's self after turning could anybody shed some light please I've checked fluid level is correct and I have no leaks.
