![]() | Home > Technical > tdv6 crank failure causes |
Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73 ![]() ![]() |
The design is a bit odd as the shells are not tabbed or indexed in any way and are just held in place by friction and compression. On occasion this allows the shells to rotate which can block the small oil ports. Once the lubrication is hampered the failure of the crank is inevitable. On the SA forums there is quite a bit of speculation that poor fuel can contribute to a failure but I am not convinced that this is the case.
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
thanks for reply |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
Are the shells tabbed on the 3.0 TDV6?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4518 ![]() ![]() ![]() |
I believe they are on the 3.0 |
Brill, thanks. I'll let him know.
