Home > Technical > Grey/White Smoke, Sulphur Smell, Rattling and now won't star
muddyfield
Hi all,
I have a 2008 TDV8. Last night I had a short journey to make. The car started fine. When I pulled up at the lights, the car was vibrating badly and the idle tickover dropped. As i pulled away the car had lost power. I then heard a rattling sound from under the car. The "Engine System Fault" message appeared on the dash, so I pulled over and turned the engine off.
I noticed some grey/white smoke from the exhaust and a strong sulphur smell.
Now the car will turnover but won't start. The car is on the drive ready to be picked up by the dealer, but I wondered if anybody had experienced anything similar.
My main concerns are turbos or the cat.
Any thoughts ?
Thanks.
Post #437055 Fri Sep 19 2014 12:03pm
Blown turbo. When mine blew there was white smoke and that rather unpleasant smell. No rattle though. Mine would start and idle, albeit very poorly. 2012 SDV6 - it's missing a couple of cylinders
Post #437074 Fri Sep 19 2014 3:10pm
muddyfield
thanks for the reply.
That was my initial thought however the dealership have take a look and they believe an injector has failed.
Once replaced and tested, I will update this thread.
Post #437076 Fri Sep 19 2014 3:11pm
muddyfield
Quick update on this.
Body currently off, engine out and is being stripped down next week.
Looks like a broken connecting rod or bent/broken con rod. If this is the case, it would explain why the piston crashed in to the injector which broke the tip.
More to follow.
Post #438407 Fri Oct 03 2014 6:53am
mark.b
2007 Range Rover Sport TDV8 HSE Stornoway Grey
What milage has your done and has it had a full service history
many thanks
Post #438446 Fri Oct 03 2014 4:13pm
Leeser23
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
having just bought the V8 I have notice a few threads on about turbos.
Is this a common fault with them ?? If so anything to avoid or watch out for ??
nick 2007 HSE V8, steps fitted, interior & reversing LED's, Black badges
Post #438447 Fri Oct 03 2014 4:28pm
muddyfield
hi,
Just over 60k with a FSH.
Literally used for school runs, I think it's been on the motorway twice in the last two years so seldom goes over 3k RPM.
We're having the engine replaced and replacing the turbos as a precaution.
Post #439582 Thu Oct 16 2014 11:35am
Leeser23
ouch !! 2007 HSE V8, steps fitted, interior & reversing LED's, Black badges
Post #439609 Thu Oct 16 2014 6:08pm
