![]() | Home > Wheels & Tyres > Run Flats on a RRS? |
RangeRoyer Member Since: 28 Jul 2014 Location: Worcestershire Posts: 21 ![]() ![]() ![]() |
I have picked up a RRS HSE 2010 model and I see that the vehicle is fitted with Pirelli P Zero run flats on the front axle with factory fitted Conti on the rear. Not sure if a standard RRS alloy rim is designed for Run Flats. Is there anything fundamentally wrong with what I have here? Thanks for any advice on this.
Where did you pick your motor up from? Dealer or private sale? Personally, i would change all the tyres to the same make, ie Pirelli Scorpion none runflats. I would never mix tyres on any of my vehicles. |
None other than Stratstone of Mayfair. The sales person was not aware of the fact that different tyres were on the vehicle. They were different on the same axle. Hard to believe but true. I have moved the wheels so that at least they are the same on each axle. The alloys are perfect so I suspect that when the reconditioning was done the wheels were put back on without checking. |
No surprise there then. |
There is more: They are not sure what an Auxiliary Heater is doing on a RRS and stated that RRS is not fitted with an Auxiliary Heater. As I can see the device under the bonnet I pointed out that the vehicle certainly does come with the aux heater as its under the bonnet. They asked me to let them know more about this.
DavidHirst Member Since: 07 Sep 2013 Location: york Posts: 93 ![]() ![]() ![]() |
Had an X6 that needed 2 new rear tyres. Was told that you cannot mix and match run flats and standard tyres on same vehicle. MY 09TDV8 |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5644 ![]() ![]() |
Agree mixing tyres is not recommended - furthermore run flat should only be fitted if you have tpms |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
Yes a brilliant point Muddy . |
Take it straight back to s |
