![]() | Home > General > rr sport suspension |
speedy2009 Member Since: 04 Apr 2014 Location: driffield Posts: 35 ![]() ![]() ![]() |
What spec is your car |
stekar Member Since: 14 Mar 2013 Location: norway Posts: 3 ![]() |
06 rr sport but been so for a while unf |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9131 ![]() ![]() ![]() |
Possibly the corner valves need changing. There are three blocks: one for each axle and one for the reservoir. They're not expensive. 2012 SDV6 - it's missing a couple of cylinders
Peanut Member Since: 31 Jul 2012 Location: Leicestershire Posts: 110 ![]() ![]() |
Intriguing! Mine is also a bit bumpy - on a speedhump road in Oadby my lad's Fiesta handles them better...
I seem to remember some mention of it on Disco3 when I was researching an issue. Some people said that fitting new valve blocks helped soften their suspension. 2012 SDV6 - it's missing a couple of cylinders
Suspension is usually quite compliant unless pump or ride heights are at fault. Worth getting these checked first then look at valve blocks. Have done lots of experimenting with FF to get a combination of ride quality and lower centre of gravity/cosmetic look. Even if you drop the car 10mm from standard by fudge/computer set, the ride becomes harsh. 2x TDV6. SE and HSE. Both returned to sender with issues👀
