Home > Technical > Sunroof help
wireworld
Sunroof help
Could someone with a sunroof just confirm that one touch opening makes the roof slide all the way back. When I do this this I get a bit of buffeting in the car and have to slide it forwards slightly or open a window. I recall that in one of my other cars (BMW I think) the roof slid 80% back then if you really wanted the rest you could press the button a second time and this avoided the problem. Not very important really but just intrigued.
thanks
Post #427426 Tue Jun 17 2014 9:54am
Guyzer73
WW
Not sure about the MY2013 but if I remember correctly on my 2006 the 'one touch' on the button slides the roof back approximately 80%. I then have to hold the button to slide it further back.
Don't know if they changed that in later MYs....
Post #427431 Tue Jun 17 2014 11:17am
wireworld
Thanks. I've tried the reset but it just seems to be a MY13 feature!
Post #427432 Tue Jun 17 2014 11:25am
muddywheels
Milk Float Man
http://topix.landrover.jlrext.com/topix/se...amp;page=1
Quote:
3. Sunroof close/tilt switch:
Wherever possible remove any
snow, ice, dirt, and leaves etc. from
the sunroof mechanism before
closing. Failure to do so may
damage the sunroof mechanism.
• With the roof closed, briefly press to
tilt the sunroof open.
• With the roof fully open, briefly press
to close the roof.
Press the button again to stop movement.
4. Sunroof open/close switch:
fully open. Press again to stop
movement.
• With the roof tilted open, press and
hold to close the roof. Releasing the
switch will stop roof movement.
The sunroof will operate for 30 seconds
after the ignition is turned off, provided
that a front door is not opened.
5. Sun blind:
• To open, push upwards on the textured
part of the handle. Then, slide the blind
into the panel between the sunroof and
the headlining.
• To close the sun blind, pull across the
aperture until it locks in place
 Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #427434 Tue Jun 17 2014 11:30am
wireworld
Again, thanks. So that's just the way it is! Neutral
Post #427435 Tue Jun 17 2014 11:34am
