Home > General > Towbar electrics - how much?!
sagalout
Bought a dirtbike to have a bit of fun on, which led to the purchase of a trailer and a second hand detachable tow bar. I assumed the electrics would be pretty reasonable as I can see looms on ebay for £65. Rang up the local towbar place my dad has used for years and they've quoted £280 including parts and fitting.
Is that normal? From what I can see its 'plug and play' rather than having to splice into existing wiring etc. Anyone done it themselves?
Post #426973 Thu Jun 12 2014 4:24pm
DavidHirst
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Buy the genuine L/R kit off fleabay and fit it yourself Thumbs Up Did mine, took around 2 hours. Really is a straight forward fit. MY 09TDV8
Post #426988 Thu Jun 12 2014 7:38pm
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
From memory Ripon Landrover charged me 100-150 pounds supplied and fitted.
Is there a software update required to let the rear parking sensors know when they electrics are active ie when a bike rack or trailer is attached? 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #427046 Fri Jun 13 2014 6:56am
RRS_PAT
I've done mine . it takes a couple of hours and I'm no amateur mechanic in fact the opposite Laughing
You can find instructions on topix so you can see the steps. I think I paid £120 ish for the wiring kit.
It does require bumper off which though daunting is actually fairly easy. A search on here will find a YouTube link.
On both my RRS I didn't bother with the software update, though someone like Bodsy can do this. You just press the parking sensor off button.
I might see how much as it seems more annoying on MY11 than my MY06.
Good luck with it
Pat 2011 Autobiography Santorini Black
Post #427410 Tue Jun 17 2014 6:41am
simple1
The "software" mod does a lot more than parking sensors. Turns off rear fog light when towing, uses a different map on the gearbox and turns off rear parking sensors on earlier cars. Having suffered the results of a botched install from dealer on my first V6, it is advisable to get the function switched on in canbus to avoid gearbox going into freefall. Those who have got away with it are lucky rather than wise. Bow down 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #427463 Tue Jun 17 2014 6:18pm
Ian.H
I just bought these (£109). Fitted in about 2 hours (half in the dark with a torch). Wasn't the easiest thing to feed the wiring down behind the bumper of the HST, but alas, finally all went home and works a treat.
I already had a small loom that connected to the green plug behind the boot trim which I suspect cancels the PDC sensors.. but my light board has a foglight and this works when turned on.
Cheers..
Ian
Post #439972 Mon Oct 20 2014 9:38am
johnunleashed
2007 Range Rover Sport Supercharged HST Java Black
Ebay http://www.ebay.co.uk/itm/Towbar-Electrics...41687087e0
very easy to fit 2007 SUPERCHARGED HST
Post #439976 Mon Oct 20 2014 10:17am
Pufftmw
I did a "How To" here
http://www.rrsport.co.uk/forum/topic29704.html
Simples
Post #439978 Mon Oct 20 2014 10:49am
myfirstrrs
I was told that it is necessary to remove the bumper but from the referenced "how to" it seems that it might not be necessary. Could you please confirm this?
Post #439993 Mon Oct 20 2014 12:55pm
johnunleashed
Hi mine has the hst bumper and did not remove it , 2007 SUPERCHARGED HST
Post #439994 Mon Oct 20 2014 12:58pm
Disco_Mikey
Some of the newer models require the bumper to be removed to fit
Post #439998 Mon Oct 20 2014 1:25pm
myfirstrrs
MY2010? Where would that fit with this?
Post #440000 Mon Oct 20 2014 1:28pm
Pufftmw
I didn't for this installation. Bumper is very easy to remove but there was no need.
Post #440007 Mon Oct 20 2014 2:27pm
