Home > Technical > differance in compressors
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
i got another compressor to fit and its got a external filter where the pipe should go, could anybody please help
Post #425816 Sat May 31 2014 8:12pm
Disco_Mikey
That is a compressor from a FFRR. Will not fit your RRS properly, different fittings...
Post #425827 Sat May 31 2014 10:14pm
cossiedave
cheers for the help mate
Post #425828 Sat May 31 2014 10:23pm
adigorn
Can be adapted though Thumbs Up Wink
Post #425853 Sun Jun 01 2014 10:14am
cossiedave
How do you adapt to it and what do I need
    Post #425881 Sun Jun 01 2014 5:00pm
    adigorn
    First thing wiring
    RRS one is male plug FFRR is female (corresponding wires are same color so if you wish you can use old compressor as donor) make sure you make it as long as possible to be able to connect to the car
    other thing is that brass silencer
    what i am doing is :
    i am removing it together with its threaded ring and instead
    i am fitting half of the connector used to repair air hoses (i would not know the proper name for it)
    matching diameter of the bigger pipe on the car (10mm if i recall correctly)
    easier done than said Thumbs Up
    Post #425889 Sun Jun 01 2014 5:46pm
    cossiedave
    i bought 3 bits today , 1st bit replaces the exhaust thing, 2nd bit pushes onto it and 3rd bit connects to that so you can push the 10 mm pipe in ,total cost 5 quid so just need to cut connector off
    Post #426025 Mon Jun 02 2014 8:17pm
    cossiedave
    Pump fitted and calibrated and working great
    Post #426157 Tue Jun 03 2014 2:25pm
    adigorn
    Post #426177 Tue Jun 03 2014 6:50pm
