![]() | Home > General > Should dealer replace rear bushes on new used car purchase? |
PHinett Member Since: 21 May 2014 Location: Birmingham Posts: 63 ![]() ![]() ![]() |
Picking up my car tomorrow which has had an MOT done today...an advisory is that there is a slight play in the rear bushes.
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
I would make sure they are changed before you take it! your car has 8 wishbones (2 at each corner) with 3 bushes in each. most places replace the wishbone at £170 odd plus fitting as it is not worth just relacing 1 bush in case the others go soon (new bush £50) i had 3 go recently and was charged £700 for that and some other bits and pieces
I asked if they could be done he's not too keen on that, said it was only an advisory.
Pushed the dealer to get them done...he said i tell you what we'll call it a day then and i'll give you your deposit back...
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
A no-brainer of course you should expect a visible fault to be rectified before taking delivery.
I would say you had a lucky escape with that, as it is never just 1 bush that goes! I take it wasn't a LR dealer that you were buying from, they would have noticed that before sale and adjusted the price to cover that! It's a pretty common fault!
Definitely was! I think I rushed into it when the excitement took over |
Trouble is, next guy that sees it will be told it has a full mot, and won't see the advisories! Let's hope the next guy knows his stuff!
ha i have also just spotted that they have re-listed the car at £21,000 now up from £19,000, i can't get my breath with these guys! |
micalee Member Since: 24 Apr 2014 Location: Warwickshire s Posts: 241 ![]() ![]() ![]() |
Can you post a link to the RRS so we know what to avoid? |
Sure...here are the crooks:
Smashing - cheers |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9131 ![]() ![]() ![]() |
Big shiny wheels. Rusty disk hubs and poor rear disk/pad wear. Priced at 20.5k now. |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Not confusing. Because he had you pinned as a problem punter. ![]() Having sold vans in the past, I can tell you there's two sides to this type of thing. The trade view is often that an advisory is a non issue - its passed the test and its not a new car. So some wear and tear is to be expected. If you want faultless, buy new many say. In the van job, I would have also refunded a punter who was insisting advisories be done. Because 9/10, that same guy will be in your life over all kinds of little non-things he notices later on. Not saying you are that guy at all you understand, but that will be how the salesman views it. He will think he got off lucky by cancelling the deal, just as you did. Although I do think its a stretch labelling them "crooks" as you did above. Its their car, they can ask what they like for it and sell it to who they like. |
