![]() | Home > Maintenance & Modifications > RRS 2.7 tdv6 oil pump rattle |
| gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494
they all make a ticking sound when started ,well everone i have owned has,mine has a brand new oil pump in and still does it ,to be honest i dont think its an oil pump issue i think it is egr or tappet |
| sestorious Member Since: 12 Apr 2013 Location: doncaster Posts: 91
Cheers for reply mate ! ive had two new EGR valves so surely it cant be them ? the tappet thought seems logical, ive been told them oil pump is low down in the engine isnt it, so the oil has to travel up to the top before it quietens down ? Is there nothing i can do to rectify it ? also how come it lasts a couple more seconds now ive changed the oil ? PS it castrol ol so no rubbish ?? Cheers again |
i really wouldnt worry about it mate ,every one iv owned has been exactly the same,the one i have now has just had engine rebuilt and it still does it,if it is tappet related i would think the new oil is thinner so drains out quicker |
cheers yeah that sounds about right mate ! Its just a shame it does it you would think with the so called build quality it wouldnt do it ! |
Ok just to add again to this post regarding oil change, I've just been driving my car an the oil light came on then off then on etc. it seemed to come on wen I was stationary then wen I moved it went off any thoughts guys please I've got a panic on ??? |
did you fit a gen oil filter,was it fitted correctly and correct oil grade ,dont drive it |
I'd expect the correct oil and filter were fitted the garage I took it was my best friends. He has looked after my cars for years. I'm waiting for him to get home to ring me. If for any reason it's not the right oil or filter why would that cause this problem mate ? I'm sure it's 5w40 magnetec he uses ? If it is correct parts wat could be causing it ? Also would I need to recover car to him or can I drive it 3 miles ? Cheers |
That is the same oil I use mate and its fine. The oil filters can be a little tricky to fit and I always use gen ones ..personally I wouldn't drive it as I have just spent nearly 3k on an engine so maybe a bit paranoid. If you want some very experienced advice try disco Mikey he has helped me a lot in the past silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Actually I think its 5/30 magnatec I use. Will check in morning |
Just spoke to my mate he has used 5w30 oil with a Bosch oil filter. He told me to recover it in the morning he will get a genuine oil filter an try again. Could it be the oil pressure switch ???? It's funny how wen I was stationary the oil light came on but wen I revved it went out ???? |
That is usually a sign of low oil pressure obviously when you rev it the oil pressure rises hence light won't illuminate ..let's just hope its an oil filter problem..yes could poss be an oil switch silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
If it is summat to do with oil pressure and it's not the filter OR the switch wat else could it be mate ? It seems funny how this all started after an oil change ? |
If everything else is ruled out you will be looking at crank/oil pump problems ..mine was crank which ended up in an engine rebuild..but as you say only since oil change surely it has to be related |
Fingers crossed ! I've just rang RAC they are sending a guy out to look at it first (protocol) if he can't fix it they will arrange for it to be recovered at a time to suit me eg in morning. Wen I was driving to my yard, it drove perfectly no knocks or bangs so I'm praying its summat small ! |
| All times are GMT |
