Home > General > Just had rrs at 160 mph
Page 2 of 4 <1234>
Guyzer73
Hunter whilst I agree it's to do with gearing and aerodynamics, it also has to do with bhp on a like for like basis.
2 Bugatti Veyrons set up identically with regards gearing, aerodynamics and weight but with a 500 and 1,000bhp engine respectively will not reach the same Vmax in real world conditions. In the real world the 500bhp Veyron would run out of steam earlier because it has insufficient/ less power (bhp) to punch through the wind resistance created by the speed its traveling.
Taken from wiki:
Power
The power required to overcome the aerodynamic drag is given by:
P_d = \mathbf{F}_d \cdot \mathbf{v} = \tfrac12 \rho v^3 A C_d
Note that the power needed to push an object through a fluid increases as the cube of the velocity. A car cruising on a highway at 50 mph (80 km/h) may require only 10 horsepower (7.5 kW) to overcome air drag, but that same car at 100 mph (160 km/h) requires 80 hp (60 kW). With a doubling of speed the drag (force) quadruples per the formula. Exerting four times the force over a fixed distance produces four times as much work. At twice the speed the work (resulting in displacement over a fixed distance) is done twice as fast. Since power is the rate of doing work, four times the work done in half the time requires eight times the power.
Therefore power is relevant Wink
Post #422490 Sun Apr 27 2014 12:56pm
hunter
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Well obviously power is important..but you can have as much bhp as you like...if the gearing isnt right and the ADs its just not happening.... Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more
Post #422493 Sun Apr 27 2014 1:53pm
If the gearing is sufficient then having "as much bhp as you like" does make a difference. That's the point! Rolling Eyes 2012 SDV6 - it's missing a couple of cylinders
Post #422505 Sun Apr 27 2014 3:42pm
hunter
with the right gearing you could do it with little bhp...but you can have as much bhp as you like and if the gearing is wrong..its not going to happen... Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more
Post #422506 Sun Apr 27 2014 3:45pm
flydive
Maybe you need all of them?
Maybe an improvement on any of them will improve max speed? '08 RRS TDV8
Post #422510 Sun Apr 27 2014 4:53pm
Gavin Beecham
The point is that a rrs with standard gearing and 600bhp wont do 160. If it had 1000bhp it wouldn't do 160.
Hunters points are completely relevant.
If the gearing was raised, the aerodynamics and suspension uprated and with a long enough straight it would do 160. The point is it wont do that with a remap.
If the op can clarify what he has actually done and what his gearing is then the top speed at a certain rpm can be calculated.
And as Hunter has said, the difference between 147 and 160 is massive ( and massively expensive to achieve )
Post #422512 Sun Apr 27 2014 5:25pm
No you can't, that's the point! You have to have enough power to overcome the drag.
Agreed. 2012 SDV6 - it's missing a couple of cylinders
Post #422520 Sun Apr 27 2014 6:51pm
I'm not arguing that the RRS won't do 160mph without major alterations. I was merely discussing the general principle of power/drag/gearing. 2012 SDV6 - it's missing a couple of cylinders
Post #422521 Sun Apr 27 2014 6:52pm
Gavin Beecham
Well at least we're all agreed on that!
And that was the point I ( and I think Hunter ) was making!
The op must have thought he was still in the pub with his mates when he said his RRS could do 160 Laughing
Post #422523 Sun Apr 27 2014 7:04pm
speedy2009
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
As I have my own engineering company I make ratio gear so I can modify any thing I want
Post #422525 Sun Apr 27 2014 7:22pm
Guyzer73
Just to add I don't understand why the standard gearing won't manage 160mph... I'm not talking if the drive train can take it but if it theoretically can reach 160mph...
Now as my standard geared 2006 SC does approx 74mph at 2000rpm and the RRS is limited upwards of 5000rpm and the gear ratios don't change with speed, therefore a linear progression, 5000 divided by 2000 equals 2.5.
Therefore 2.5 x 74 = 185mph, therefore by my calcs the standard gearing does satisfy the requirements.
Now onto the matter of drag. The equation I found to calculated the power required to overcome drag is:
Power (W) = Drag force x velocity (m/s), where drag force is:
D = Cd x 0.5 x density of air (1.204kg/m3 at 20C) x velocity2 (160mph=71.53m/s) x frontal area (2.170x1.817m)
Therefore the equation is:
Power = (0.37 x 0.5 x 1.204 x 71.53 x 71.53 x 3.94) = 321,187 Watts
321,187W = 431 hp
Therefore, theoretically it's possible. But obviously this excludes the friction of the tyres on the surface, and aero buffeting (drag created through lift) etc...
But in principle 160mph is possible...
Post #422526 Sun Apr 27 2014 7:22pm
JPR 1
Shocked Current Volvo XC90 R Design T8
Gone 2010 TDV8. Stornoway Grey
Gone VW R50, AUDI S8, ML320 Sport, FFRR V8
Stolen 2007 TDV8.
Post #422532 Sun Apr 27 2014 7:58pm
Gavin Beecham
321,187W = 431 hp
Guy
This is really interesting and I completely agree that in principle 160 is possible.
But, as I have said before, the op is deluded if he thinks a remap will make his car capable of 160 on the road.
Post #422539 Sun Apr 27 2014 8:23pm
So why would you want to change the ratios of your sport in the first place? This is becoming more and more unbelievable each time you post. As said earlier, its all pub talk imo. You can get any 5.0L supercharged sport down to 6mpg just by flooring the accelerator from a standing start.
Post #422543 Sun Apr 27 2014 8:46pm
Jonny Fresh
Post #422611 Mon Apr 28 2014 4:36pm
Page 2 of 4 <1234>
