Home > Maintenance & Modifications > Non AFS headlight compatible?
Grimps42
England 2005 Range Rover Sport Supercharged HSE Rimini Red
Hi I have a RRS SC 2005 with AFS headlights however I am no doing a 2010 conversion the DRL new headlights all seem to be non AFS can I use these in my upgrade or do I need to do wiring or recoding? In order for them work without a fault code?
Martin
Post #421098 Sat Apr 12 2014 10:12pm
Disco_Mikey
You will need either:
AFS lights, to stop the warning light coming on the dash
Someone to disable the AFS feature in the cars CCF
The 2nd option is much easier, quicker, and probably cheaper too Thumbs Up
Post #421102 Sat Apr 12 2014 10:25pm
Grimps42
Hi there
I have valeo 2010> AFS headlights for my conversion but the light remains on when I offer them up to the car. When I put the old ones back the light goes out on the dash?
It must be something to do with the 16 pin headlamp connector or the LCM lighting module? As everything on the lights work indicators all bulbs etc except the AFS function?
Has anyone resolved this issue please?
Post #424542 Sat May 17 2014 7:23am
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
Hi
Any luck with this?
Have got the same issue on mine and am fed up of watching the light flashing everytime am driving.
Would like to know if you had any luck resolving this?
Post #449745 Sun Jan 25 2015 6:31pm
