Home > Technical > STARTER MOTOR FAULT
CMLE
United Kingdom 2009 Range Rover Sport TDV8 Autobiography Santorini Black
STARTER MOTOR FAULT
HAS ANYONE ELSE HAD AN ISSUE WITH THEIR STARTER MOTOR?
2009 RR SPORT 3.6 TDV8.
OCCASIONALLY THE CAR JUST TICKS WHEN THE KEY IS TURNED, IT THEN STARTS NORMALLY THE SECOND OR THIRD TIME THE KEY IS TURNED.
THE OTHER EVENING I HAD TO TURN THE KEY 8 TIMES BEFORE IT STARTED.
I AM GUESSING IT IS EITHER A LOOSE WIRE OR THE STARTER MOTOR!
ANY KNOWN ISSUES?
THANKS IN ADVANCE.
Post #420717 Tue Apr 08 2014 10:43pm
No need to SHOUT Wink
Starter motor failures are not uncommon. I had two replaced in 6 months! 2012 SDV6 - it's missing a couple of cylinders
Post #420735 Wed Apr 09 2014 8:36am
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
If it's a loose connection, be careful, there is a lot of amperage going on down there, potential for some pretty big sparks..
more than likely internal fault! 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #420802 Wed Apr 09 2014 9:03pm
CMLE
I am shouting RRSTDV8 Wink
Thanks for info.
Thanks Andrew, don't worry, I shan't be tackling the problem myself Exclamation Exclamation
Post #420818 Wed Apr 09 2014 11:03pm
range17
I have exact problem ,have put a new starter on and now this one is doing it aswell (one week old) !!!!!
Not happy Shocked zx12r
bmw gs1200 adventure
defender 90 off roader
Post #421089 Sat Apr 12 2014 7:26pm
