Home > Maintenance & Modifications > CLOCK IN BINNACLE
Peanut
CLOCK IN BINNACLE
Bit puzzled here.
Looking at Bodsys upgrades to 08 spec it shows the clock in the top line on the left.
Mine (07 VIN) has clock in lower centre part and so when you switch to computer display it is no longer visible.
Mine seems to have all the other 08 spec items such as 3 flash, SatNav on move, Lights on (green).
Any idea why and can it be changed? I have recently bought an IID GAP (already paid for itself) so would like to change it is possible.
Post #420468 Sun Apr 06 2014 6:14pm
PaulHH
Scotland 2006 Range Rover Sport Supercharged Stornoway Grey
Mines the same as yours! Although I don't get my phone book listed either. Maybe We have an original update and Bodsy now has a better latest update? 2006 Supercharged
Post #420558 Mon Apr 07 2014 10:01am
Disco_Mikey
The IID will put the clock up to the top level of the display Thumbs Up
Post #420574 Mon Apr 07 2014 1:57pm
Peanut
Brilliant, many thanks!
I will report back once I have done it.
I presume this is in CCF settings so I will need a big power supply?
I have a large amateur radio 12 amp supply, and big Ring Professional starter with 40Ah cell - hope these will be enough.
So far I have been very cautious in using the IID tool.
Post #420586 Mon Apr 07 2014 4:25pm
Disco_Mikey
It is in the "ECU Flash" section. You want the IPC option Thumbs Up
IIRC, the original IPC software is listed under IPC (old)
Takes around 60 seconds or so to program. If you have a fully charged battery, you *should" be fine without an external charger, but as ever, you do it at your own risk. For safety, always have a charger hooked up to it, or if all else fails, jump leads from a running car, to keep the volts up Thumbs Up
Post #420597 Mon Apr 07 2014 6:17pm
Bodsy
Site Sponsor
Yours is the 07 version, I put the 08 version on as it's better located and you don't lose it when looking at mpg etc.
IID uses the 08 version. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #420647 Tue Apr 08 2014 7:20am
Peanut
All done, perfect, many thanks for the help!!!
Post #421399 Tue Apr 15 2014 5:07pm
