| RRSPORT.CO.UK | ||
|  | Home > General > Parking sensor inactive..... |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | Sounds like a sensor has failed - they don't last forever & are battered daily by the elements   | ||
|  Thu Mar 06 2014 6:30pm |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | Thanks Peachy.
|  Thu Mar 06 2014 6:33pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | I had mine read by a diagnostics tool - pinpointed the exact sensor that was out - it may be a loose wire or connector -  unfortunately it's a bumper off job, which is easy if your that way inclined.The only problem is the fasteners underneath become a little brittle over time & tend to break.
|  Thu Mar 06 2014 6:41pm |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | Thanks again dude.
|  Thu Mar 06 2014 6:59pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | Here you go -   | ||
|  Thu Mar 06 2014 7:06pm |
| gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494    | Hi mate. Easy way to find the faulty sensor is sit in car engine running foot on brake obviously and activate the sensors is be close enough to anything that would make them work. Get your mate or Mrs to put there ear to each sensor and you will hear a clicking noise. The one that doesn't click is faulty..PS don't run anyone over  | ||
|  Thu Mar 06 2014 7:11pm |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | You guys are great!
|  Thu Mar 06 2014 7:22pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | Your welcome but if you take the bumper off & it's a sensor what you gonna do then   | ||
|  Thu Mar 06 2014 7:24pm |
| gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494    | Pm me if u need one I have a spare new one  | ||
|  Thu Mar 06 2014 7:26pm |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | I'll check to see if they are all clicking first.....
|  Thu Mar 06 2014 7:38pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | gazzc - would you recommend changing all 4 that way it's a job done once & once only   | ||
|  Thu Mar 06 2014 7:39pm |
| gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494    | To be honest peachy I don't really know  | ||
|  Thu Mar 06 2014 7:59pm |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | ......ahhhh....well, my RRS is Stornaway Grey as is the bumper but the sensors are in the bottom black plastic part and are black. | ||
|  Thu Mar 06 2014 8:01pm |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | Perhaps mine is just a wire?.... | ||
|  Thu Mar 06 2014 8:02pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
 good luck
 good luck I bought a new one for mine ages ago and when I cameto fit it was just a brittle/broken wire   been fine since
