![]() | Home > Technical > engine ecu tdv6 |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
Needs to be a new one. 2nd hand cant be recoded to another car.
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
Hope your right mike but scanner won't communicate so thinking the worst case silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Do you think a booster starter could damage my ecu |
It could have done. May have caused a voltage spike, and fried something.... |
Yes that's what I was thinking especially with it communicating at first. If that's the case I might be selling it as it is. I have had enough |
i have removed the ecu and there is no sign of water ingress around the plugs etc,we cant understand why it should not communicate with the scanner,any thoughts |
how/were can i get my ecu tested silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Help |
SingeRRS Member Since: 22 Sep 2009 Location: Garage Posts: 127 ![]() ![]() ![]() |
Why don't you try talking to one of the re-mappers who is associated with the site - I am sure they can probably help tell you if the ECU is fried? |
thanks for reply ,i have found a company in devon that might be able to test it thanks anyway |
ecu tested today and is fine,so back to the drawing board car still wont start,the guy that tested ecu told me to build all the front end back up on the car and then call him out again |
