Home > Technical > tdv6 turbo actuator
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
tdv6 turbo actuator
Recently bought a tdv6 sport with damaged crank ,engine is out and stripped now.I heard that there can be a problem with turbo actuator on this engine.any advice on how to check it while its out. Thanks silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #410072 Sat Jan 18 2014 8:02pm
Disco_Mikey
Check the rod attached to the actuator. They tend to seize up, causing ESF faults.
Lube and free off, or replace the rod Thumbs Up
Post #410094 Sat Jan 18 2014 9:09pm
SingeRRS
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
My MY11 TDV6 is in the garage at the moment with a seized turbo actuator rod. There is a TSB and a LR Kit to 'upgrade' the linkage to prevent seizing (aka a design fault that allows water and road dirt to corrode the original linkage - mine after 3 years and 30k of mostly motorway miles). I understand it is inexpensive so probably worth fitting while it is accessible.
When I get the bill I will post the LR part no.
Post #410102 Sat Jan 18 2014 9:54pm
gazzc
Thanks very much for both replys. Much appreciated silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #410104 Sat Jan 18 2014 10:07pm
gazzc
thanks i will do
Post #410105 Sat Jan 18 2014 10:08pm
gazzc
thanks think i will replace rod while its out,whats esf silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #410169 Sun Jan 19 2014 3:51pm
Disco_Mikey
ESF = Engine System Fault
Warning message displayed on the dash Thumbs Up
Post #410245 Sun Jan 19 2014 11:26pm
gazzc
thanks silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #410268 Mon Jan 20 2014 9:41am
