Home > Technical > No throttle response
greyheadgit
This morning I drove my RRS 2.7D off the drive, put foot on accelerator and nothing happened for about 5 secs. It happened the other day too but only the once.
Anyway, thought it was because it was cold. Went to pull out at the junction, luckily nothing coming and no response again nothing for a 5-6 secs.
Pulled off at roundabout, same thing but noticed big plume of smoke in rear view mirror. Work 35 miles away so thought it would improve when warmed up but no stayed the same all the way to work. Should have turned back home really.
I have had it re-mapped by Quantum a while back, just before Xmas for the 3rd time as their promise of better MPG just didn't happen after first two attempts, MPG went down a lot compared to their promise of up.
Could this have an affect or is it The dreaded Torque Converter. In neutral it revs up fine, but it gear it doesn't want to pick up at all.
Post #408637 Wed Jan 08 2014 10:42am
Disco_Mikey
EGR valve Thumbs Up
Post #408641 Wed Jan 08 2014 11:10am
greyheadgit
Disco-Mikey
Thanks for the advise and when I drove it to my local Indie garage, it behaved itself no problem, however when he plug his reader in it came up with------------------------------------you guessed it right the egr valve. So have ordered a blanking kit and will be on this this weekend. Cheers.
Post #408729 Wed Jan 08 2014 9:35pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Had the same problem, egr valves blanked off and problem solved. Be careful not to round off the soft alloy bolts if blanking off the valves....
Post #409070 Fri Jan 10 2014 10:42pm
greyheadgit
Thanks for the advice. Do I leave the valve connected when blanked off or what.
Have seen the blanks on ebay for 50 quid.
Post #409171 Sun Jan 12 2014 12:11am
Tony666
You've got two options, leave everything connected and install blanking plates, should be about £8, or buy a kit that enables you to remove some components and hoses, cost about £50. From what I can gather there is no difference performance wise, it's just that some people prefer to de-clutter the engine bay if components are not needed, though this option foes involve a little more work. If anyone else knows otherwise please share the knowledge Question
Post #409184 Sun Jan 12 2014 8:18am
Disco_Mikey
As above Thumbs Up
Net result is exactly the same, all comes down to personal preference
Post #409187 Sun Jan 12 2014 9:23am
simple1
As above but get the mapping checked after as removing/blanking off can change what the engine requires in fuel. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #409287 Mon Jan 13 2014 10:03am
gogsy1956
I have been reading with interest these posts regards EGR vLves, if it is so common place to blank off or remove these why are they fitted in the first place ?. Surely they must perform some worthwhile function... Maybe one of the more knowledgeable can explain Question 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #409291 Mon Jan 13 2014 10:33am
simple1
As the title says, exhaust re circulation. They basically feed the engine the exhaust gas at low revs/idle to Reburn gases which will contain particles of diesel. It is a way for manufacturers to get engines to conform to Euro5 spec engine emissions. Works great in theory, just not so well with modern sulphur free fuel that clogs up systems with Black Death carbon. Only countries that require these by law are Holland and Switzerland. Hope this helps Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #409293 Mon Jan 13 2014 10:51am
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Just remember EGR'S can't be blanked off on RRS 2007> onwards. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #409294 Mon Jan 13 2014 10:58am
gogsy1956
i knew someone would enligten me ! Bow down Bow down 2010 RRS, TDV8
22" overfinch
Post #409328 Mon Jan 13 2014 3:50pm
greyheadgit
Where are the 8 quid ones from and where are the 50 quid ones from as only seen the 50 quid ones on ebay.
Post #409341 Mon Jan 13 2014 5:19pm
Tony666
Apologies for being technologically challenged but I don't know how to post the link, but if you type 'tdv6 egr blanking' into the eBay search bar you'll find a selection for under £10. There is a set from staffs 4 x 4 for £5 with free delivery.... Very Happy
Post #409366 Mon Jan 13 2014 7:34pm
greyheadgit
Thanks Tony, I will get on it so that I can get the damn things fitted this weekend as its driving me nuts at present.
Post #409520 Tue Jan 14 2014 8:13pm
