Home > Maintenance & Modifications > Oil for Range Rover Sport HSE SDV6
Terryrrs
I have been looking at the oil specs and it seems you have to go for Ford Approved oil specs. This means if you use castrol edge you have difficulty in sourcing it. unless you go to a Land Rover dealer as mine is still in warranty I expect I will have to do this. Normal castrol edge 5w30 is C3 whilst you need C1. Would there be problems if you were to switch to normal castrol edge. Also what is the average oil consumption I can expect.
Post #407628 Tue Dec 31 2013 5:20pm
jimbg
You can use Shell Helix Diesel Ultra AF-L 5W-30 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #407632 Tue Dec 31 2013 6:11pm
ravingmad
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
I also use Shell Helix Diesel Ultra AF-L 5W-30.
Recommended by Opie oils. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Driving a milk float for now.
Post #407646 Tue Dec 31 2013 8:12pm
Terryrrs
Thanks for the advice not sure what oil landrover put in from the factory does anyone know? Also is it advisable to do an early first oil change on a RRS.
Terry
Post #407732 Wed Jan 01 2014 2:33pm
jimbg
I think it is Castrol Professional or something like that. You cannot buy it unless you are in the trade I believe.
I originally spent ages searching for a suitable oil and the Shell one was the only one I could source, you can buy the Castrol from your LR dealer though. 2026 P460e Autobiography on order
2006 HSE
Post #407735 Wed Jan 01 2014 2:44pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Miller oils do the correct spec one. Bought mine via Opie Oils when on offer
Post #407741 Wed Jan 01 2014 3:21pm
jimbg
You are right it is this one, XF LONGLIFE C1 5w30 :- http://www.millersoils.co.uk/automotive/td...sector=Car
Never seen it on sale though in any outlet I have been in. 2026 P460e Autobiography on order
2006 HSE
Post #407746 Wed Jan 01 2014 4:18pm
Mike767
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
I have a 3.0 TDV6 HSE (2011). The oil spec is WSS M2C 934 B as the car has a DPF fitted. I'm not sure what spec the SDV6 requires, but if you need the same oil, Carlube Triple R 5W 30 C1 is available. I got mine delivered from Euro Car Parts for under £40 for 10 litres. Very Happy
Post #408598 Tue Jan 07 2014 10:10pm
