![]() | Home > Technical > Confused |
Maybe a faulty sensor ? 16MY Estoril Blue SVR.............
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4520 ![]() ![]() ![]() |
Will need a new bottle. Well known issue, very common. A new bottle is only around £30 or so for the TDV6. Would expect a similar price for the S/C |
stevew Member Since: 16 Oct 2013 Location: solihull Posts: 75 ![]() ![]() ![]() |
Where's that located peachy ? And thanks again for the other week with the steering wheel, air bag has not gone off |
Cheers Mikey |
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 ![]() ![]() ![]() |
I'm With Mikey on this having just changed mine for exactly the same reason.
PaulHH Member Since: 24 May 2013 Location: Highlands Posts: 98 ![]() ![]() ![]() |
I've got the similar intermittent warning, I also get a Engine System Fault even more intermittently and Peachy mentioned a Coolant Temp Sensor was his cause, replaced sensor and cleared both faults so that is where I'm starting. 2006 Supercharged |
PaulHH - so the sensor is now changed ? - any good |
Hi Peachy, still hasn't arrived from Dan yet, my last post was badly worded, 2006 Supercharged |
