Home > Maintenance & Modifications > Lower Arms
mixerman
Lower Arms
Can anybody tell me how long it will take to change the front lower suspension arms on my 06 RRS and how long Landrover allow. Thanks.
Post #402313 Fri Nov 15 2013 8:25pm
flack
If the bolts come out without needing cutting then its a couple of hours per side..
Flack Thumbs Up
Post #402322 Fri Nov 15 2013 10:05pm
mixerman
Ok thanks for that flack Thumbs Up
Post #402324 Fri Nov 15 2013 10:08pm
Disco_Mikey
Even if they do need cutting, its still a couple of hours per side Thumbs Up
Post #402325 Fri Nov 15 2013 10:11pm
jochem00
2 hours max, and I believe I did it even in less than 1,5 hours last week.
-jack car up, remove wheel, take centre cap of the rim and put wheel back.
-jack car down.
-now mark possition drive shaft nut and take of the drive shaft nut.
-jack car up and put on axle stands
-take wheel of and plastic gearbox protection.
-mark position of the allignment bolts with marker
-release bolt of lower suspension arm bolt, and jack up suspension arm, use hammer to release boltjoint from arm.
-lower jack
-remove shockabsorber bolt and the two already marked suspension arm bolts.
-now pull the wheel hub towards you while the driveshaft slides slightly out of the hub and you should be able to remove the complete suspension arm from the car.
-with the hub in current possition put the new arm back in put everything back in place.
Post #402705 Mon Nov 18 2013 3:59pm
Disco_Mikey
If the bolts come out Whistle
If they do, it takes 40 minutes a side Laughing
Post #402711 Mon Nov 18 2013 4:12pm
