![]() | Home > Maintenance & Modifications > 7 year service SC |
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
You forgot the tube of ky jelly. |
mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298 ![]() ![]() ![]() |
You can see the service item list in the sticky at the top of this section: http://www.rrsport.co.uk/gallery/albums/us...0Miles.pdf But you are just trying to tempt me into another rant about 'oil flush' aren't you? I don't want to repeat myself so just consult #snake oil, #rip-off, #robbin bast ![]() Be interesting to insist they show you documentary evidence that Land Rover recommend oil flush before you will authorise it ![]() I wonder how many engine failures pouring this rubbish into the sump causes every year. 2008 MY Java Black TDV8 HSE ![]() |
LOCUST Member Since: 02 Oct 2013 Location: ESSEX Posts: 75 ![]() ![]() |
after a few phone calls i have got it down to £440 at a reccomended independant.... |
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
Apart from normal engine oil, filters etc. I assume you’ve done or will do all these as well !! |
Seriously?....... Anyone had that done? and the OP won't need timing belt changed as he has a TDV8 which doesn't have a belt. 2008 MY Java Black TDV8 HSE ![]() |
You're right Paddi - I just pulled the info off the Workshop manual |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Mine is seven years old. It cost three and a bit including anti roll bar bushes and an aircon re-gas at Landranger (not with cam belts but mobile guys here do that for circa £275).
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441 ![]() ![]() ![]() |
Hello
Whizzee111s Member Since: 17 Sep 2011 Location: Basildon Posts: 53 ![]() ![]() ![]() |
Where a outs in Essex are you? Taking my s/c to ongar bridge to have the supercharger cooling pump as it putting the car into limp mode. Mines a 55 plate with80k on the clock which according to its service book is due for a 'B' service Freelander SE - Gone
Im in harlow mate, there is an inde called broadfields and the guy lives in harlow so can take it in for me, they come highly reccomended |
