![]() | Home > Technical > Black Vue Camera |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
I tried dental floss to break the bond with sawing action but in the end found twisting and wiggling it got it loose. You will need new sticky pad and they are ridiculously overpriced - I will look where I got mine |
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
Thanks for that - I'd a feeling t'was going to be a fiddle ! |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Mine came with 2 sticky pads, double check your box |
Cheers nick |
i keep meaning to move mine, as i positioned it without using live view, as i hadn't worked out how to do it |
hondagoneda Member Since: 06 Jun 2013 Location: Cheshire Posts: 22 ![]() ![]() ![]() |
Interesting article - but, what is a Black View Camera. I hope I am not the only one here with this question |
It is a camera stuck on the windscreen to record the drivers view - useful if like me you have to to prove innocence when a lying |
as said its a video camera, records to a SD card and gives others the amusement of seeing other pillocks on the the road, you might have seen the Russian you tube videos of dangerous driving, crashes
Thanks Muddy and Nick. I wondered where that type of vid footage came from. SDV6 HSE, Indus Silver/Ebony
Anybody know if this is correct? I'm assuming the heated windscreen elements are sandwiched within the glass laminate so there's no risk of damaging them when removing the Blackvue's adhesive pad. |
Correct- no issue to front but would be careful if rear |
Cheers |
Kenzi Member Since: 24 Jun 2013 Location: Perth Posts: 101 ![]() ![]() |
Does anyone know how much they actually are on the group buys? |
Says PM him for prices - I paid £229 for mine back in May and showing £249 on website before forum discount |
