Home > General > engine system falult |
M55RK H Member Since: 20 Feb 2010 Location: STOKE-ON-TRENT Posts: 35 |
Hi, Guys wonder if you can help driving home to night noticed on the display it said engine system fault went into slow mode then just died,, wont even start up , engine turns over ok but thats it MARK |
Tue Oct 08 2013 8:21pm |
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 |
run out of fuel due faulty sensor |
Tue Oct 08 2013 11:30pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Or it's done what mine did and digested the turbo deals 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Oct 09 2013 7:03pm |
hi guys the fault code is p0087 p140a and 0100 any one know these MARK |
Wed Oct 09 2013 7:40pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
P0087
Wed Oct 09 2013 8:31pm |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
Could it be a problem with one of the injectors, leak off leading to low pressure? I had this on a FF Rangie just wouldn't start! |
Thu Oct 10 2013 10:18am |
DK3000AR Member Since: 19 Sep 2013 Location: Dakar Posts: 18 |
I too have been suffering from the all-systems errors for months now. To date, have changed EGR valves, new battery, new air, oil and fuel filters, replaced brake bulbs, and replaced brake light switch.
Fri Oct 18 2013 9:38pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4339 |
In tank pick up filter blocked
Fri Oct 18 2013 10:18pm |
Mikey - always a doyen of knowledge on these matters!
Fri Oct 18 2013 10:26pm |
Not done a How-To for fuel tank removal. Run out of space in my sig for adding all of them as it is
Sat Oct 19 2013 8:51am |
Today I had the fuel tank off to give the in-tank fuel filter a good clean. As you can see - they were not pretty and you can even see shiny bits of metal in the swirl pot suggesting that something ain't right in there:
Sun Oct 20 2013 7:30pm |
Incidentally, now that I think back I reckon that this pump has been kaput for a while as last time I replaced the fuel filter the garage used a vacuum pump on the fuel bleed valve in the engine bay to get her going. And I don't actually remember hearing the fuel pump at any point (it's usually quite noticeable I believe??).
Sun Oct 20 2013 7:33pm |
All fixed now guy,s thankyou it was the fuel pump in the tank, hadit replaced, running sweet now MARK |
Mon Oct 21 2013 1:00pm |
