Home > Maintenance & Modifications > Steering wheel wobble under braking
roscopcoltrane
2008 Range Rover Sport TDV8 HSE Zermatt Silver
Guys/Gals (are ther any on here)
Probably a well asked question however I am not technical in any way, when I brake at anything above 50MPH I get a small wobble through the steering wheel. Only happens under normal braking, full on the pedal produces nothing and stops OK. Can anyone give me a hint before I put it in the shop.
I would hazard a guess at discs but only if I wasn't in such esteemed company Very Happy
Thanks
Post #394217 Sat Sep 07 2013 6:30pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Could be as easy as you've lost a few wheel balance weights.
Post #394224 Sat Sep 07 2013 7:20pm
roscopcoltrane
Ah, good one, had the alloys refurbished and only been happening since, cheers Surprised
Post #394230 Sat Sep 07 2013 7:28pm
Disco_Mikey
Check your wheel nuts are tight Shocked
Post #394254 Sat Sep 07 2013 9:35pm
roscopcoltrane
Cheers guys, I just get in the thing and drive, will check wheel nuts also, Very Happy
Post #394258 Sat Sep 07 2013 9:48pm
