Home > Maintenance & Modifications > anyone changed their brake lines/pipes ?
tanloverluke
i've noticed that my brake lines are a little rusty and therefore wanna nip this in the bud before winter. has anyone changed their brake lines themselves and want to share how they found the whole experience ? Maybe even where you bought the replacement pipes from?
seen some people attempt it on the disco site and seems straight forward, though they do mention that a good brake pipe flaring tool is an important tool Thumbs Up Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #392281 Tue Aug 20 2013 2:58am
Disco_Mikey
A good tool is very important Laughing
I bought one of these: http://compare.ebay.co.uk/like/39032527489...mp;ff14=65
Cut the pipes above the centre silencer, female pipe union and flare on the steel side, male union and flare on the copper side. When the pipes are off, measure the old steel pipe, and cut the new copper pipe to the same length. Flare both ends and fit, then bleed the brakes, and check for leaks Thumbs Up
Post #392283 Tue Aug 20 2013 6:53am
