![]() | Home > General > Does a 2010 tdv8 hse have bi xeons? |
ajp166 Member Since: 10 Jul 2011 Location: london, UK Posts: 241 ![]() ![]() |
Also what are bi xeons? Is it the when the low and high beam are xeons? |
Ok thanks but my mate has an 08 plate Audi s8 and his bi xeons use the same bulb for normal lights and when he flashes high beam but on my rrs when I flash my high beam its using the other bulbs next to the main xeons and those lights are not white , so the high beam is a different bulb... But I have my build spec and it says I have adaptive bi xeon lights so I'm totally confused! My mate thinks my build spec sheet is wrong |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
The RRS uses a xenon for dipped beam. It also uses the xenon for high beam too by way of a moveable shutter. Hence it's a bi-xenon. For some reason, LR also fitted a halogen light to act as a "fill in" beam when on high beam. That's the second light you see coming on. So when on high beam you are actually using 4 bulbs - 2 xenon, 2 halogen. 2012 SDV6 - it's missing a couple of cylinders
Perfect explanation thanks a lot mate really appreciate it. |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 ![]() ![]() ![]() |
Hmm..
Yes thanks also. The main issue was that halogen light that comes on made my mates think they were not bi xenon but now I realise the halogen light is just a fill in.. |
