Home > Maintenance & Modifications > WHICH GLUE to use?
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
WHICH GLUE to use?
I am positioning and installing daylight running lights. I need to build the bracket up with a piece of metal to get the right angle and then the bracket is going to be stuck to the PVC trim under the grill. So I am looking for a glue that will remain flexible but firm and will adhere to both metal and PVC. Any suggestions.
This post has been edited by the site administration team
Moved to modification section Smile
 Andrew Kennedy
Post #389495 Sun Jul 21 2013 4:56pm
Saeedasghar
2006 Range Rover Sport TDV6 HSE Java Black
Some sort of silicone adhesive should do the trick. Think autocare do a cheap effective clear one off the top of my head
Post #389508 Sun Jul 21 2013 8:18pm
rigsby
How about a glue gun, the result is a rubbery glue that seems to give adhesion to most surfaces MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #389510 Sun Jul 21 2013 8:52pm
