![]() | Home > General > This is going to cause a stir. but !! |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Thought the MOT now checks for a cat if it should be there, it needs to be come MOT time |
felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203 ![]() ![]() ![]() |
It's a diesel and its a 55 plate. Don't think it matters ? Could be wrong though. |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 ![]() |
Cat not MOT tested on diesel only a smoke test is done..
Lot of work for not much gain. It's turbo so isn't going to sound loud. I removed my rear boxes too and the car was plenty loud enough. I then removed centre section to have a look and started the car whilst box was off. It sounded the same with and without centre box. 2x TDV6. SE and HSE. Both returned to sender with issues👀
cat back system. Sounds ok to me. |
Sounds good for a V6... Mine was V8 so sounded great anyway |
Well that's the sound I want. And if that don't float my boat when its done the rrs is going up for sale and I'm buying myself c63 amg. |
Now there's a noise. Had an E55 and SL55 and they did grumble proper. |
I've been threatening the rrs for a while now with replacement. And it doesn't seem to make any difference so I keep spending money on it hoping its gonna make me want it more. Similar situation with the wife. |
Now I can relate to that..... |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9097 ![]() ![]() ![]() |
You're driving an early 2.7 and you're blaming the vehicle for being "not enough"? |
I have considered a tdv8 or even a supercharged. Wondering what mine is worth, low miles 58 thousand java black very clean 22" super sport reps ?? Prob could get in a tdv8 or charged for not much more money. I do like my tax bracket tho but not the end of the world to pay a bit more. |
I don't understand the low tax issue - these things cost over £100 to fill the tank. Do any sort of mileage and the fuel cost outweighs the tax difference by some margin. For £200pa I'd rather have an RRS that goes properly...and no matter what you do to the V6, it'll never sound as good as one of the V8 varieties! 2012 SDV6 - it's missing a couple of cylinders
