![]() | Home > General > Burning Smell |
dryden1407 Member Since: 22 Jan 2013 Location: montrose Posts: 65 ![]() ![]() ![]() |
we got something like that on our old ffrr,,it would drop a "smidgeon" of coolant onto the exhausts from somewhere resulting in a burning smell sometimes when getting out,,it only needed a quarter litre of coolant every couple of months and we eventually traded it
V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145 ![]() ![]() |
Do you notice if the burning smell is stronger around the nearside rear wheel ?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9153 ![]() ![]() ![]() |
What was the temperature at the time? If it's cold outside and the coolant isn't up to temp then the FBH will kick in. It's been a bit cold down here the last day or so - what's it been like in Thurso? 2012 SDV6 - it's missing a couple of cylinders
reid7774 Member Since: 12 Apr 2012 Location: Thurso Posts: 73 ![]() ![]() ![]() |
Will checkdryden1407 will check coolant and keep an eye on it, next time I smell it will check around rear wheel area v8sc, RRSTDV8 did read something about that in search, it has been cold, down to 3-4 degrees last couple of days, could you explain what it actually is and does please as am not that mechanically minded so everyday a learning day |
