Home > General > Drivers Side Door (need help please)
cisco1
Hi Guy's
Need a little help please, we realised yesterday evening that while pressing the lock button on the fob the passenger door and rears lock.
For some strange reason the drivers side door will not lock.. Even when i press the button on the fob twice.
The alarm sound as if to say a door is open, so now i have to lock the drivers door from inside and the use the fob for the rest.
I have done some reading and thinking it could be the drivers sidevdoor latch.
Any help or if anyone can point me in the right direction i would greatly appreciate it.
Thanks in advance.
Post #383273 Thu May 16 2013 9:40pm
Disco_Mikey
Yes, needs a new latch. Very common issue, and relatively cheap and easy to fix Thumbs Up
Post #383274 Thu May 16 2013 9:53pm
I had my drivers door latch replaced a couple of years ago now, about £150 ish i think from the dealer, 6 months later the passanger door did the same. Crying or Very sad As Mikey says common problem now on older sports, mine was a 2006 model.
Post #383278 Thu May 16 2013 10:12pm
cisco1
Thank you guy's really appreciate your support as always.
Post #383289 Fri May 17 2013 7:05am
