Home > Maintenance & Modifications > Spare tire winch not working :(
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
I had not spare tire and now when I wanted to get it down I turn and turn but it does not go down.
I pulled and nothing.
What should I do?
Is there anything I can do? 91 BMW 850CSI
Post #380967 Fri Apr 19 2013 9:30pm
Disco_Mikey
Get a helper, and pull down on the cable while you unscrew it. If that does not work, you may be able to take yours apart and unjam the cable.
If none of these work, then its a new winch
Post #380972 Fri Apr 19 2013 10:07pm
Fatandre
How can I take it apart? 91 BMW 850CSI
Post #380973 Fri Apr 19 2013 10:13pm
Brianx5
Scotland 2013 Range Rover Sport 3.0 TDV6 HSE Firenze Red
I had the similar problem, once you remove the winch drill out the 4 rivets and take it appart rewind the wire and rebuild and pop rivet back together again remember to grease it up, if not repairable e-bay approx £90.
Post #381016 Sat Apr 20 2013 3:41pm
Fatandre
How did you put it back together after drilling it out? 91 BMW 850CSI
Post #381028 Sat Apr 20 2013 5:57pm
mse
Rebuilding is the reverse of...
Tbh I would order a new one, they have been modified since your original Mike
2014 Facelift Discovery
Post #381037 Sat Apr 20 2013 6:36pm
Brianx5
As mse has said once you find the fault rewind back on the spool and use large flange pop rivets to secure the top hat remember to insert the rivets with flat upwards
Post #381069 Sat Apr 20 2013 11:06pm
