Home > Maintenance & Modifications > Full brake upgrade to brembos and larger rear discs help
Nelly28
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
Hello there,
I'm needing a little help with buying discs and pads the upgrade,
I've purchased a pair of hi-gloss black brembo front calipers from a supercharged sport and have purchased the rear calipers and carriers from a 09 TDV8 the pads for the front I can get as they came with nearly new ones installed so I can see what they look like but the rears didn't I'm thinking of going for EBC yellow stuff and the EBC discs all round or keep the with the brembo pads and discs
The problem is this is all going onto my 56 plate TDV6 so I'm not untie rely sure what size of discs to get
Any help would be great
Nelly Better to have it and not need it!!!!!!
Post #379088 Fri Mar 29 2013 4:18pm
Disco_Mikey
Front discs are SDB000624
Rear discs are SDB000646
Personally, I would steer clear of EBC discs. Have had a few issues in the past with warping.
Also, I would advise regular pads in the rear. EBC pads tend to be a softer compound, and give a higher braking effort. Not what you want on the rear of the car with standard front pads.
If you uprate the fronts at the same time, there won't be the same issues
If you need any more help with anything, let me know. I have done this upgrade more than a few times Thumbs Up
Post #379105 Fri Mar 29 2013 7:11pm
Nelly28
Thanks for the advise,
Il stick to the brembos then,
The whole lot is getting done at the same time once I'm back from offshore
Is there anything else needs doing or that I've priced the dust covers but think il just edit the ones that are in it the now
Cheers again
Post #379108 Fri Mar 29 2013 7:26pm
Nelly28
I was going to do the front end this weekend but I'm down the road at the in laws for Easter in carnoustie (where we are from) and il get my ear chewed if I spend half the day missing about with the jeep when I'm ment to be with the family which is fair enough Better to have it and not need it!!!!!!
Post #379110 Fri Mar 29 2013 7:31pm
Disco_Mikey
The rear dust shields are the same, think the fronts are different, but you can use them anyway.
Fitting them is a perfect excuse for a couple of hours away from the in-laws Whistle
Post #379120 Fri Mar 29 2013 9:54pm
