![]() | Home > Maintenance & Modifications > TDV8 MAP sensors clean |
| TheDB Member Since: 07 Apr 2009 Location: Southerner Posts: 96
Did mine two weeks ago. Quick and simple to do. Just 15 minutes or so.
| jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
my mpg has drastically dropped with no change to driving style at all. averaging 17mpg if lucky.
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Yep, that's the stuff. |
My rear anti roll bar is leaking and needs to be replaced. This was spotted 3 months ago but I couldn't afford to do it. :/wonder if that has gotten worse and is affecting mpg 07 TDV8 + BAS map |
Yep. That is what I used too. |
Unlikely its the leaking ARC bar. Check the easy things like tyre pressures and dragging brakes. After a run feel the wheels (not the discs) and if one is warmer than the others that would indicate a binding brake. When was the air filter last renewed? An inexpensive easy DIY job. Remember that colder weather can affect fuel consumption as the FBH uses a bit and switching on screen and seat heaters means the charging system draw more power from the engine. 2008 MY Java Black TDV8 HSE
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738
I would put it down to the colder tempreatures for the drop in mpg, using more electrics, taking longer for your vehicle to warm up etc etc. |
I think this is it, cold weather. Otherwise can't explain the sudden drop. We're talking about going from getting 330 miles a tank to 250 - for the same kind of driving 07 TDV8 + BAS map |
| CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59
These sensor are diferent from TDV6 ones, the TDV6 seem to have a hole and no electrical thingly is seen. The photos of the TDV8 sensors posted seem to be temperature sensor and MAP combined. there are more wires in the plug, TDV8 have 4, TDV6 have 3, related to 1 more values to control (NTC for temp). see:
