![]() | Home > General > 6m wait + purchase = oh ye...h? |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
Picked up my new motor after looking hunting for some time.
do you mean use the satnav screen? |
Sat nav screen yes but not in navigation mode. In 4x4 info mode where the wheels and chassis are illustrated. RRS gone
looks pretty kosher. does this mean not actual fault and just sensor? pls say yes |
If it was a sensor you would have one wheel reading a different colour. Needs a fault code reading I fear. Check the fluid anyway, if it is low you will need to check why. That's where the bad news starts, but won't spoil your Friday night..... 2x TDV6. SE and HSE. Both returned to sender with issues👀
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9132 ![]() ![]() ![]() |
Check the battery, check the alternator. If both ok then it's time to check other things. Definitely requires the codes reading to see if anything is showing there. 2012 SDV6 - it's missing a couple of cylinders
the dealer hooked it up to their fault reader and nothing showed up hence why they said red herring and just cycle ignition to "reset it" |
Stick a meter across the battery and read the voltage when engine is off and when idling immediately after starting. 2012 SDV6 - it's missing a couple of cylinders
ok will pick one up tomorrow and test this.
Yep. Ideal. Voltage should be 12 at rest and anything up to 15 when running.
im not sure what they used. looks like a tablet with handles. not sure if it was official code reader. will find out tomorrow.
Sounds a little bit low but not by miles. 2x TDV6. SE and HSE. Both returned to sender with issues👀
