Home > Technical > Wondering at 50 plus mph
Mitchsafety
United Kingdom 2008 Range Rover Sport TDV6 SE Santorini Black
Hi all sport owners, I have an issue with my car when driving along the road any slight change in canvor results in the car going all over the place, I have had the 4 wheel alignment reset to factory settings , this did improve it slightly.
But on my way up the M6 unless I was in the middle or fast lane car was all over the place.
Any advise or help please.
Mitch Bow down RR Sport TDV6
RR DHSE gone
RR 4.0 V8 HSE Gone
RR 4.6 V8 gone
RR Classic 5.0 V8 (the Duke) miss you .... Sad
RR 3.5 Classic
Disco 300tdi
Disco 200tdi
Landrover series 3 (1984)
Post #377375 Mon Mar 18 2013 6:54pm
shepp
who did the alignment, and did you check that the vehicle height was correct befor the alignment? if the height was wrong when alignment was done, if the height was wrong then it could be wrong. Also could be lower arm bushes, the large hydro one is usually the culprit as it has a lot of movement when worn.
Post #377404 Mon Mar 18 2013 9:29pm
The near side lane up the M6 probably had groves in it caused by HGV's all running in the same tracks, very common on a lot of motorways especially on uphill sections. Thumbs Up
Post #377424 Mon Mar 18 2013 11:06pm
drdelrrs
^^^^ I'd be tempted to agree with Ady's opinion above.
If you're on 20inch and/or low profiles these will make it feel worse.
I'd keep running it for a little while longer and see if its on all road types.
You might want to jack up each corner and spin the wheel to cCheck none of them are running out of true! - its possible to balance a bent wheel so even if you've had them balanced and aligned they can still be out.
Post #377523 Tue Mar 19 2013 8:57pm
Mitchsafety
Good Morning Guys,
well it seems to be getting worse, along the A143 and any surface that's not even.
its now got to the stage that i am getting uncomfortable driving it, i am getting it looked at at the weekend.
Car is 4 years Old and i have only had the car since end of Jan 2013, all four tires were new and seem to be wearing evenly.
Will let you guys know the outcome.. Thanks God for Warranties RR Sport TDV6
RR DHSE gone
RR 4.0 V8 HSE Gone
RR 4.6 V8 gone
RR 3.5 Classic
Disco 300tdi
Disco 200tdi
Post #377563 Wed Mar 20 2013 10:06am
Disco_Mikey
Does the suspension clonk, or knock at all?
Could be worn/soft suspension bushes, but if it is not as bad in the 2nd and 3rd lanes, I would be tempted to say it is the grooves worn in the road from the HGV's.
Tyre pressures can make a huge difference to the way a car drives, as well as the make of tyre. I have had issues in the past with budget tyres...
That said, it may be something suspension related, or possibly a wheel bearing on its way out
Post #377564 Wed Mar 20 2013 10:12am
Mitchsafety
Further developments
Hi , Have been told i need all the bushes replaced , as this is causing the wondering and the two front tyres are now needing replacement after just over 3000 miles, so much for getting a newer Range Rover .
has any other readers had this problem , i was told by an independent garage this is a common problem with RRS over 4 years of age ????
Mitch RR Sport TDV6
RR DHSE gone
RR 4.0 V8 HSE Gone
RR 4.6 V8 gone
RR 3.5 Classic
Disco 300tdi
Disco 200tdi
Post #379410 Tue Apr 02 2013 11:02am
Mitchsafety
a happy outcome
Hi Guys , just a quick up date and god do i feel silly Rolling with laughter
After all the worry and me thinking i had been sold a dud car needing thousands of work , i had the Car fully checked over at an independent LR Garage and all the 4 wheel linement was OK and the Tracking was perfect, as a last resort he checked my Tyre pressures, 46 in the rear and 40 to 44 in the front, Needless to say there lies the issue, once tyres set at correct settings and i test drove for a 20 mile trip its like a different car all together.
Lesson Learned is when you buy a car from whats believed as a reputable dealership , and after a 140 point safety inspection , check the tyres.
I am now sending a legal letter to them as Tyre pressures were on the check list to see if i can get the funds for the two tyres it has destroyed as a result of over inflation.
I know people are going to say i could have checked them , but when you spend over 20K on a car you don't think there is likely to be over inflation to all 4 corners .
Mitch RR Sport TDV6
RR DHSE gone
RR 4.0 V8 HSE Gone
RR 4.6 V8 gone
RR 3.5 Classic
Disco 300tdi
Disco 200tdi
Post #380481 Mon Apr 15 2013 4:57pm
mse
I spent £60k on the car, first thing i check - fluids, pressures and nut tightness
Glad you got it sorted Mike
2014 Facelift Discovery
Post #380483 Mon Apr 15 2013 5:11pm
^^^^ Confused Really Question Shocked
Post #380502 Mon Apr 15 2013 8:15pm
mse
Yep - within the first day or so. update the cars specs (with the other cars we have) and check the fluids etc.
I check all the cars fluids/pressures regularly - its a good habit to get into Mike
Post #380507 Mon Apr 15 2013 8:53pm
I agree, prevention is better than a cure, are you a transport manager by anychance in your spare time Question Wink
Post #380509 Mon Apr 15 2013 8:58pm
BKHK
I don't agree with mse on very much but i do on this topic. I check whatever can be checked 2 weekly on both vehicles. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #380564 Tue Apr 16 2013 2:33pm
Jonny Fresh
I've not checked a tyre pressure or fluid level on mine since I got it 2 years ago! I bet i'm not in the minority as well.
Post #380566 Tue Apr 16 2013 2:43pm
mse
BKHK and i might be in the minority - a first for me, but it looks like twice for him Whistle
Ady - no not a transport manager, just got members of the family who are engineers and they have drummed it into me. Mike
Post #380593 Tue Apr 16 2013 5:58pm
