![]() | Home > General > Brakes |
paulrudd Member Since: 11 Nov 2012 Location: Doha Posts: 8 ![]() ![]() ![]() |
So after 41k kms I had to change the pads and discs on my 2010 RRS 5.0 S/C.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9135 ![]() ![]() ![]() |
I had all four corners done using Ferrodo pads and discs for £550 all in. That was at a local indie. 2012 SDV6 - it's missing a couple of cylinders
simonsti Member Since: 29 Apr 2006 Location: staffs Posts: 193 ![]() ![]() ![]() |
Mine is still on original brembo discs after 58k miles, 3rd set of pads though. 2014 Nara Bronze SDV6
That's cos it's a V6 ![]() ![]() Mine suffer due to towing car trailer or caravan for most of its annual mileage. 2x TDV6. SE and HSE. Both returned to sender with issues👀 TDV8 Sport HSE...... Gone. Loved it but it didn't love me!! Now rolling in MY10 Fullfat TDV8 Vogue. Slammed it to go round corners🙈 Cruising daily #56 mph in a Volvo V8. 😱 Lots of other toys in the cupboard...😜 |
If you could see the driving in Qatar you would understand how we get through brakes ! |
I also tow, 2 to 3 times a week with a horse box and on holiday with a twin axle caravan.
merlin1 Member Since: 16 Sep 2009 Location: cornwall Posts: 110 ![]() ![]() |
How easy are the rear discs to do any resetting with the handbrake ? |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
i wouldnt do the rear brakes myself, very expensive if you mess then up, and Im as good diy mechanic, Bodsy's brake bible ( on here somewhere ) tells you how to do it, but you do need to be precise. Fronts are as easy as any other car 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ![]() |
It really isn't that hard or requires great deal of ability. 2x TDV6. SE and HSE. Both returned to sender with issues👀
ok, then i will read it again, as I wasnt sure of the tensioning of the brake shoes 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ![]() |
I didn't follow the instructions on here, a fellow racer who works for LR said replace discs, tighten tensioner/adjuster until shoes lock then back off seven clicks. I very rarely use my handbrake, loading car trailer is only time that comes to mind , and never had any issues with EHB. 2x TDV6. SE and HSE. Both returned to sender with issues👀
