![]() | Home > Maintenance & Modifications > Singing brakes |
Hi All
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Or you've got some grit or small stone stuck in there.
cheers Enjin.
If that doesn't work then find a friendly garage with a pressure air hose and get them
norlan Member Since: 21 Jun 2011 Location: Moray Firth Posts: 45 ![]() ![]() ![]() |
Had this a while ago and it turned out to be a sticking brake piston. |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 ![]() ![]() ![]() |
Very badly worn pads on worn discs will do that too, but shouldn't be speed dependent. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
If the noise is coming from the rear, it could be the beginning of seized EPB shoes |
