Home > Technical > sat nav
smurf
sat nav
can anyone help,my sat nav puts me somewhere down south when clearly i am in the midlands.
i have tried to take out the disc and re-insert it but i still have the problem.
is there anyway it can be re-calliborated,i have tried the option on the screen but same fault.
Post #376328 Mon Mar 11 2013 3:21pm
Maybe the car has aspirations..... Whistle Laughing
Sorry, can't help Embarassed ON THE WAY: BMW F21 M140i
Post #376330 Mon Mar 11 2013 3:30pm
jimbg
Re: sat nav
Has it just started doing this? Do you have option to look at the satellite signal strengths in your menus's
Has the car been moved 10's of miles with the system shutdown?
Post #376347 Mon Mar 11 2013 4:52pm
Endjin
Scotland
You can calibrate the Sat Nav in the settings menu. try that first.
If the car has been moved some distance without wheels turning
i.e. on back of a break down lorry, (I know- such an unusual event for a RRSPORT) Whistle
it can lose it's place and will need re calibrated via the menu. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #376348 Mon Mar 11 2013 4:55pm
smurf
I tried to calibrate it via the menu but it didn't work,and yes it has been on the back of a breakdown truck lol
Post #376394 Mon Mar 11 2013 9:08pm
jimbg
OK, that is why it is confused!!
It needs resetting, what does the manual say?
Some sat nav's find the correct position after a half hour or so.
Post #376398 Mon Mar 11 2013 10:00pm
Bodsy
Site Sponsor
you can try disconnevcting the + cable off the battery and touching the + CABLE to the body. Just make SURE that the battery is definately disconnected and you dont have an Aux battery installed as well.
This will drain all ECU's of power and when you re-start, it should sort itself oiut. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #376419 Tue Mar 12 2013 12:24am
