Home > Technical > RRS 2006 TDV6 Engine seized?
livonian
2006 Range Rover Sport TDV6 HSE Siberian Silver
Driving normally then flapping noise from offside front. Flapping stopped, battery and oil warning lights came on and power disappeared. Battery power ok but engine won't turnover. Lifted to dealers but anyone any ideas before the service department opens on Monday?
Post #376137 Sat Mar 09 2013 6:50pm
Texstar
Sounds very much like timing belt snapped or belt tensioner detached, same destructive effect,(becoming a quite common occurrence with pre '09 TDV6's), really hope it's not this,as it will more than likely require a replacement engine . RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #376140 Sat Mar 09 2013 7:48pm
livonian
Thanks. Hope you're wrong but that's what the RAC man thought too!
Post #376142 Sat Mar 09 2013 8:49pm
Disco_Mikey
06MY's were usually OK for cambelt tensioners falling off. It was the 07/08MY's that had issues...
That said, the bottom ends of the 05/06 cars were not great. It has now been superceded to the same as the 2.7 in the D4 due to spun crank bearings
However, it could be something as simple as a failed alternator, or the aux belt (or its tensioner) has failed, and the battery has discharged with no belt turning the alternator. The engine has stopped due to lack of voltage, and the same lack of voltage will not be enough to turn the engine over. Both are extremely common issues, and relatively cheap to repair, so lets hope for the best Thumbs Up
Post #376149 Sat Mar 09 2013 10:27pm
Texstar
Any news on the outcome of this livonian Question RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #377107 Sat Mar 16 2013 11:44am
livonian
Ok, the LR dealer has now had a look and they say they 'can't turn the engine manually, it's looking like the crank has seized'. They've drained the oil, there's 'metal in the sump' so there 'seems to be an internal failure of the engine'. They're quoting 'worst case scenario' £10,500 inc vat for new engine and new turbo, for which I get a one-year guarantee.
I've found a company in London who will take the car away, re-manufacture the existing engine and bring it back for, worst case scenario, about £5,000 inc vat, for which I get a five-year guarantee.
Both will take about 2/3 weeks. Any opinions or thoughts welcome.
Post #377450 Tue Mar 19 2013 10:50am
muddywheels
Milk Float Man
You must be gutted Big Cry
What sort of mileage have you done and do you have FSH - subject to this I would expect a contribution from LRCS - cars like this should be good for 100's of thousand miles Rolling Eyes
My first car in 1984 was an hillman avenger with a ceased engine - got one from a scrap yard and swapped for £130 - £10k is a hell of a rise even with inflation Embarassed Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #377451 Tue Mar 19 2013 11:03am
livonian
78,600 miles and FSH. Will give it a try, thanks, but won't hold my breath!
Post #377452 Tue Mar 19 2013 11:26am
Disco_Mikey
Be very wary of "re-manufactured" or "re-conditioned" engines.
JLR + PSA do not supply replacement parts for the bottom end of the TDV6 engine. You cannot buy pistons, rings, main bearings or big end bearings.
There is also no aftermarket suppliers of said parts either.
After exchanging a few emails with various "specialists" they are not even willing to supply the parts to anyone to re-build their own engine Whistle Rolling Eyes
I am in exactly the same situation as yourself, and have done a lot of research over the last few months Thumbs Up
Post #377454 Tue Mar 19 2013 11:36am
muddywheels
Milk Float Man
Don't take no for an answer - 78k is nothing Shocked
Others on here have had contributions and can probably advise you better - hopefully they will be along soon Bow down Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #377455 Tue Mar 19 2013 11:38am
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
Would Ford (US) sell parts? Here in Oz the same engine is in the Ford Explorer.
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #377550 Wed Mar 20 2013 2:18am
garrycol
Australia
Cheers,
Gordon
I thought the Explorer was only the petrol V6 - do you mean the Territory.
I would have thought the ACCC would jump on a car company that only supplied complete engines and not component parts.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #377551 Wed Mar 20 2013 3:00am
H16UUP
United Kingdom 2006 Range Rover Sport TDV6 SE Zermatt Silver
Hopefully using Fuchs Pro-S 5w30 oil every time mine has an oil change will give my '06 a long and healthy life Shocked
There's much better oil than the standard Magnatec stuff according to the Opie Oils gurus 2006 TDV6 SE, Zermatt Silver
Post #377661 Wed Mar 20 2013 10:13pm
disco4x4au
Garry
Oops - yes, I meant the Ford Territory Diesel!
Cheers,
Post #377778 Fri Mar 22 2013 3:02am
Leytonstone
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Java Black
Hi,
actually there are aftermarket main bearings and big ends that we have managed to get which were specifically manufactured to address the problems associated with the failed mains and bigends.
ill post a picture
[/img]
Post #378973 Thu Mar 28 2013 6:32pm
