![]() | Home > Technical > Water in fuel |
Check the obvious first - did the garage remember to reconnect the water sensor? Not sure if this would give you a false reading but it is easy enough to check with a visual inspection.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4513 ![]() ![]() ![]() |
The water in fuel sensor is actually part of the filter housing.
Defty201 Member Since: 18 Feb 2013 Location: England Posts: 11 ![]() ![]() |
Thanks for all the answers.
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Had this on and off a few months ago - the message eventually went off and has been off since. FF 4.4 V8 Soooo looking forward to this bad boy
Mine came on during the floods.... sensor is prone to shorting/earthing in it's low position.
