Home > Maintenance & Modifications > Bell Auto Services
mse
flydive wrote:
But that is what I'm saying, you remove the map before taking the car to a dealer.
That is what I always do, before taking the car to the dealer, for whatever reason, I always put back the original map.
I might be wrong, but I believe doing that they should not be able to figure out the car was ever mapped.
I got that but i was talking about something different, let me explain.
Your driving down the road - the car stops with various lights, you get LR assistance out, they recovery you to a dealer - you havent removed your map - they notice this...your warranty claim is rejected.
scenario 2
You remove your map after the engine has died - LR think this is odd, we will investigate - they have your engine and ECU back (you have removed the map) the interogate it and find you had a map on and removed it. Mike
2014 Facelift Discovery
Post #374403 Fri Feb 22 2013 9:26pm
flydive
Scenario 1
I always have the BAS tool in my car.
As long as I have electrical power in the car I should be able to remove the mapping an reload the original map, takes 2 minutes(done via the OBDII plug)
Scenario 2
You do not remove the map, but replace it with the original. LR will see that the map is there, the original one. The ECU will never be without map, either you have the original or you have the modified one.
Scenario 2 does not exist. '08 RRS TDV8
Post #374405 Fri Feb 22 2013 9:36pm
mse
flydive wrote:
Scenario 2
Even Pete has said you can tell its been written to - so you can actually tell, if you look, that the original has been taken off and put back on. Granted the dealer would struggle - but you can tell.
This was a topic on the defender forum when Pete launched his tool (ive been around that long!)
So sorry its not that simple Mike
Post #374419 Sat Feb 23 2013 12:18am
Disco_Mikey
I have to agree with MSE. The dealer does not have the access to tell if the ECU has been reflashed, but if LR get hold of the ECU, they can tell the date and time of when it was last flashed, how many times it has been done, which software version has just been put on etc...
Admittedly, they would only get that involved if they suspected the car had been mapped. and for a large warranty claim
Post #374436 Sat Feb 23 2013 8:50am
flydive
Some interesting info here
http://www.disco3.co.uk/forum/topic91628.html '08 RRS TDV8
Post #375682 Tue Mar 05 2013 6:38am
mse
Yes but its not that that identifies its been remapped Thumbs Up Mike
Post #375739 Tue Mar 05 2013 6:24pm
flydive
What it is? '08 RRS TDV8
Post #375942 Thu Mar 07 2013 8:12pm
